SQL - current datasource is unavailable
i have installed Remote Desktop Manager and I have a SQL Database on an extra Server.
I thnik I managed to isntall it all correct.
Now if I am in the RDM und try to select my database (at the bottom of the programm)
--> then i get the error: The current datasource is unavailable.
I am sure that there are no firewalls that could block the progress.
Why could this error acure?
best
jpfau
All Comments (4)
Can you check the application log, you will get more information for the detail.
Post it here, I will try to help you
Devolutions inc.
hmmm i got a german version i dont think that i will be of much help =(
Info[14.09.2009 17:15] Upgrading database with version 3
ERROR[14.09.2009 17:15] System.Data.OleDb.OleDbException: Das "Connections"-Objekt wurde nicht gefunden, weil es nicht vorhanden ist oder Sie nicht über die entsprechenden Berechtigungen verfügen.
bei System.Data.OleDb.OleDbCommand.ExecuteReaderInternal(CommandBehavior behavior, String method)
bei System.Data.OleDb.OleDbCommand.ExecuteNonQuery()
bei Devolutions.RemoteDesktopManager.Business.DataSources.DatabaseConnectionDataSource.ExecuteNonQuery(String aSQL, OleDbTransaction aOleDbTransaction, OleDbParameter[] aParameters)
bei Devolutions.RemoteDesktopManager.Managers.DatabaseUpgradeAction.Execute()
bei Devolutions.RemoteDesktopManager.Managers.DatabaseUpgradeManager.Upgrade()
bei Devolutions.RemoteDesktopManager.Managers.ConnectionManager.LoadConnectionsFromDatabase(BaseConnectionDataSource aConnectionDataSource)
There is a problem with the database creation (schema upgrade). you can download a blank database here
http://remotedesktopmanager.com/download/RemoteDesktopManagerDB.zip
You can use SQL Management Studio Express to restore the database in a blank database named remotedesktopmanager.
Let me know if you got another message.
Devolutions inc.
thanks for your help...
the Problem was... that i used a database i already created on sql server.
That does not seem to work.
I created a Database using RDM and it works fine =)
best
jpfau
