Synchronizer Question
I'm beginning a deployment of RDM, and I *think* the synchronizer can do what I want. I want some clarification on best practice. I work for a retail chain with about 100 stores. All of our stores are (more or less) cookie cutter.
- I will be using a database so that all users share a connection tree
- I plan to make a template with all the connections I need for each store.
- I want to use the Synchronizer with a CSV file to populate a group with a template instance for each store.
I guess my question is, will the Synchronizer read the CSV and create all the connections in the database? Or will it "Synchronize" every time a user launches RDM?
All Comments (1)
The synchronizer has a "auto sync" option, when enabled it runs 30 seconds after each DB refresh.
My suggestion would be to turn off the auto mode in your case and either run it manually or using the command line. You can find the exact command line in the advanced properties of the synchronizer entry.
Maurice
Closed
