Need help embedding console sessions - running as administrator
OS: Windows 10 (10586.104)
RDM: 11.1.0.0
I'm trying to configure a series of embedded console sessions.
CMD.exe as my regular user
CMD.exe as my domain admin account
powershell.exe as my regular user
powershell.exe as my domain admin account
I can get this working - however, these are not running as administrator.
If I add the check to run as administrator, the consoles are no longer embedded.
Is there a way to make it embedded *and* run as administrator?
Thanks,
David F.
All Comments (2)
You need to execute RDM with the Run as Administrator as well. You can't have two different security context.
Must be some background reason.. I thought you guys were just embedding the consoles?
It is working, but over the long run, I'd like to be able to do this without having to run the entire program as administrator.
Thank you,
David F.
