Smart sizing in RDP sessions not working
the smart sizing in Remote Desktop sessions is not working anymore. When I installed Remote Desktop Manager it worked pretty well, so I set it to default for all RDP sessions. But meanwhile nothing happens, when I change the window size.
I'm not pretty sure if it soped working after installing the latest update of RDM or after I upgraded my Windows from 8.1 to 10. Could the later be the problem? Is there anything about Windows 10 that could keep smart sizing from working?
Sebastian
All Comments (5)
Could you export one of your session without the username/password? I will verify if it works on my side.
I just attached the configuration of one of the RDP sessions. I removed the hostname.
Regards and thanks for your help,
Sebastian
Could you try to set the Screen sizing mode to "Auto scale resolution"
I tested it with one server and it seems to work. Will try some others later. Thank you very much!
"auto scale" works but "smart sizing" doesn't.
BR
G.
https://www.gpunktschmitz.com
