How do I search for entries with explictely specifed username/password
I'm trying to use credential manager everywhere but I'm not sure if all my entries now under credentials manager or not. Can I search entries specifically on wether explicit username/password is set?
All Comments (10)
What do you mean by Credential Manager?
Could you post a print screen please.
I mean all passwords are stored in "Credentials" container, not directly inside invidual entries of each of machines.
In File->Option->User interface->Tree view, enable the Merge credential list with sessions in the UI options.
Is this option can help you finding your credentials?
Érica Poirier
Sorry to jump-in the thread but I think I see what you mean. You want a report is the Password usage report:
However we don't support the username/password combo.
Correct that's what I'm looking for but it looks like it's not implented.
Just to confirm the only thing missing is to be able to input the username?
May be I'm not understanding how to use this feature but how exactly I search for any entries which has anything but "inherited" in settings for credentials?
Could you give me more details about the whole scenario like why you want to do search? I think that what you need might be a new report.
I have around 500 RDP connections from different servers in different domains. My tree structure in RDP have top level folders organized by domains. Those folders have "credentials" tied to LastPass account. Every RDP connection under that folder has credentials as "inherited". This way I have 2 FA and no passwords being stored in file.
The problem is that I'm not 100% sure that every entry under top level folders are setup as "inherited" and hence some of those entires retain any other settings other then that (like explicitly specified username/password). I need to find those.
You could add to your tree view the column "User" . You will quickly see if you have an entry configured with a username and not inherited.
