Help with Quick History
First, let me say I'm a long time user since 5.5 and love it. Other than creating a template and my sessions, I haven't had the need to dive into the options too much, so forgive me if I may have overlooked.
Since the upgrade from 7.6.3.0 to 8.0.10.0 and also to 8.0.11.0, I've noticed a few things and had some questions/comments.
1) I use the quick history list quite often, and the upgrade seems to sort alphabetically rather than historical. Is there any way to change the sorting on my side or make an editable option in the program?
2) Also with the Quick History dropdown, when clicking in area of the dropdown in order to enter a host name, the result is opposite of what is expected. Instead of highlighting the host name that is there so you can type over or paste over, the actual result is the host name is selected for a millisecond and then is deselected and the cursor goes to the end of the host name. So the bottom line is I click in the area, then need to double-click to select current entry, then type or paste a hostname.
3) I also noticed if I have RDM open and I do a CTRL-F in Excel, the RDM filter dialog pops up as well as the find function of Excel. The cursor focus is clearly in Excel, and it is just a slight annoyance that this extra window pops up. Anything I can do to stop this?
Thanks for any help and keep up the great work. It truly is appreciated.
All Comments (2)
Thank you very much for your post. Here are the answers:
#1 I have added an option to disable the sort. This will be in the version 8.0.12
#2 This is now fixed as well
#3 You can disable the keyboard redirection by clicking on the little magnet in the status bar
Thanks for the quick response, I look forward to the next version.
