Keyboard/terminal-tab for Serial Port
When creating serial port, there is no option to change the backspace key mode.
Is it possible to integrate this for these sort of sessions?
Thanks in advance.
All Comments (8)
The keyboard and terminal tabs will be added for the serial port connection in the next version of RDM. Unfortunately we don't have an environment to test this yet, so it would be appreciated if you could give us some feedback on the functionality.
Thank you! Ofcourse I will provide some feedback on the functionality.
Works like a charm! Thank you.
Thank you for giving us feedback! If you have any other feature request, feel free to ask us.
Hello, I am having some difficulty getting the number pad to map correctly, is there another option that should be available here?
In the entry's properties, in the terminal tab in the general section, there should be an option for "Application keypad mode". Can you try disabling or enabling it?
That has no effect that I can see. I've both enabled and disabled it.
I take that back, once I closed the console and reopened it Disabling the setting fixed the issue. Thanks!
Closed
