Sometimes a session temporarily loses connection to the server, and it reconnects. I understand that this is just the way network protocol error correction/handling is sometimes.
BUT, when it comes back, it is in the original window state, not the Zoom state that it lost connection in. It's a minor nuisance, but nonetheless a nuisance.
Can you fix it so that a reconnected session retains the zoom setting, please?
/Jesper
Hi Jesper,
What do you mean by zoom setting?
Do you mean that you wish the scroll bar have the same position?
Do you need the window to keep the size you changed it to?
Best Regards,
Benoît Sansregret
When I connect to a session, I have it set to 2160x1350 as the initial size. On my secondary display (27" Samsung), this works great because it's 2560x1440.
If I'm traveling, my laptop is 1920x1200, so I need to zoom it to have it all fit on the screen. I do that by double-clicking the window title bar, and it resizes (using "Fit RDP window (smart sizing)") to fit neatly within my laptop display.
When it reconnects, it zooms out again to a 2160x1350, and I have to double-click the window title bar again.
Now, as I mentioned, but a huge problem, just a nuisance that it doesn't stay within the confines of my laptop display; it doesn't retain the window size I resized it to.
Thank you now I understand what you need.
I'll see what I can do.
Benoît Sansregret
