Android FHD 10” tablet – very small window of remote pc.
i use android 10" tablet with resolution 1920x1080, and connecting to Terminal Server 2003.
The window that i get of TS is very small with tiny objects.
I tried to change Display configuration in RDM, but it didn't help.
Can you help me to resolve it?
Thank you,
Gregory
Hi Gregory,
The current Android version uses the device's resolution and does not support the display configuration that is set on the connection.
This feature has been added to our todo list.
For the moment you can try pinch zooming on the RDP session window.
Best Regards,
Nicolas Dufour
Thank you, this is what i do.
And will wait for news :)
Hi Gregory,
The next release will support the remote desktop size value that is set in RDP connections.
Previously, only the default value was supported (which was the Android device's resolution).
In the Android settings section on your device, you will also be able to set a custom resolution for RDP connections that will override the remote desktop size value of all the connection that you open on your device.
Best Regards,
Nicolas Dufour
