Running my desktop @ 2560x1440 and DPI set to "Larger - 150%" breaks RDP
I have added a 2560x1440 monitor to my desktop. Because the RES is so high, i set my Text size to "Larger - 150%". After logging off and then logging back in i found that RDM itself looked "blurry" and not as sharp as any other application on my desktop. I also found that RDP refuses to let me click on the top 20% or left side 20% of the screen. I can click on everything else on the RDP session outside of a certain area mentioned above.
If I drop the DPI to "Medium - 125%", log off, log in, RDM looks sharp and RDP works fine. When i tried kicking it back up to "Larger - 150%" log off, log back in, again RDM looks blurry and RDP doesnt work.
All Comments (1)
This is know issue that we have. Unfortunately the solution is not simple. We have to rewrite the whole UI to support HDPI. This is planned for the next major release.
