Integrated Security Connection Problem to SQL Server
Hi
I tried to connect from android RDM to the SQL Server RDM Database (using integrated security). But the following error message is shown:
Login failed. The login is from an untrusted domain and cannot be used with Windows authentication.
I think connection with integrated security should be possible, but what I am doing wrong?
Best Regards
Renzo
All Comments (1)
Hi Renzo,
Is your SQL Server configured to use SSL ? If so, we do not currently support it.
Best Regards,
Nicolas Dufour
