i´m using RDM 8.0.9.0. When typing "Strg + F" in a RDP Session, the cursor/focus jumps out of the RDP session an in the Filter input of the RDM session tree....
regards
Sebastian
You can disable this shortcut by clicking on the little magnet at the lower right hand corner
But this disables all other shortcuts as well, even if no session is opened...
Also in an embedded web session, Ctrl + F doesn't get captured by RDM.
I don't use any other keyboard shortcuts in RDM so this solved my issue, thanks!
