RDM 11.0.2.0 Enterprise Focus Issue with Entry Availability Options
When trying to change the Availability of different Entry types, the screen goes behind the options menu. You are able to interact with it however the screen never comes to the front. Every once in a while it will even disappear behind the main application and the only way to release the application is to hit the excape key to cancel out of the option menu or kill RDM.
All Comments (1)
This will be fixed in the next build.
