Problem upgrading to v11
The installer appears to work find until the progress bar is only a few pixels from being full, and then just sits there.
Pressing cancel and selecting yes to cancel the installation does nothing. The only way to stop it is to kill the installer process or restart.
In the case of killing the installer process, v11 actually works doing so leaves the installer in an incomplete state and will want to roll back the install to v10.x when you next try to install anything else. I can actually run v11 perfectly while the installer is sitting this hung state, but I need to resolve this so it will stop trying to install.
In the case of restarting, it will keep trying to install with the same problem automatically on restart. If I cancel the install that occurs on restarting the software appears to be installed but won't run.
Is anyone else experiencing this?
All Comments (13)
Is it RDM 11.0.0.0 or 11.0.1.0 that you are trying to install?
Did you download the .msi or the .exe?
It's 11.0.1.0
I've tried uninstalling the existing install and installing from a downloaded copy but have the same issue,
Could you try to download the zip file of RDM 11.0.1.0 and copy/paste the content in your installation folder.
When you launch RDM, does it open RDM 11.0.1.0?
Sorry, I forgot to provide you the download link
http://remotedesktopmanager.com/Home/Download
I did that and it appears to have fixed it, but now I've updated again to 11.0.3 and it has exactly the same issue again.
How long did you wait for the installer? Does it still rollback by himself?
I waited about 2 hours and this morning it hasn't rolled back, but it also won't start up so I'm having to uninstall and reinstall again.
Actually, it isn't even appearing in the list of installed applications even though the files are all there.
Anyway, I've used the msi this time and the progress bar stopped at a different spot:
Again, I can actually run it now but because of this stuck installer process windows won't allow me to install/update anything else and I expect it will roll it back when I next restart.
I really need a solution for this.
Could you try to install it from the zip file?
http://remotedesktopmanager.com/Home/ThankYou?f=RDMbin
Thanks David.
Will this solve my issue going forward or can I expect the problem to keep happening? I ask because I did the same thing last time and the problem came back.
I'm not sure what is the problem with the installer. I suspect that it could be the .NET Pre-JIT that ould hang.
Could you try something for me?
- Open a Windows Command line with the Run As Adminstrator
- Browse the installation folder and execute this batch file: OptmizeRDM.bat
I can only assume the mountain of errors that occurred is normal...
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Interop.DevolutionsTerminal.dll
Microsoft (R) CLR Native Image Generator - Version 4.6.79.0
Copyright (c) Microsoft Corporation. All rights reserved.
All compilation targets are up to date.
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Interop.CoRgreceiverLib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Interop.CoRgreceiverLib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Interop.IWshRuntimeLibrary.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Interop.IWshRuntimeLibrary.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Interop.MSTSCLib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Interop.MSTSCLib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Interop.OfficeCtrl.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Interop.OfficeCtrl.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Interop.PDFXCviewAxLib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Interop.PDFXCviewAxLib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Interop.SHDocVw.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Interop.SHDocVw.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Interop.ULTRAVNCAXLib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Interop.ULTRAVNCAXLib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Interop.VisioViewer.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Interop.VisioViewer.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Interop.WFICALib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Interop.WFICALib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Interop.VMRCClientControlLib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Interop.VMRCClientControlLib.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install IWSManClient.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install IWSManClient.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Microsoft.WindowsAzure.StorageClient.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Microsoft.WindowsAzure.StorageClient.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Devolutions.Utils.dll
1> Compiling assembly C:\Program Files (x86)\Devolutions\Remote Desktop Manager\Devolutions.Utils.dll (CLR v4.0.30319) ...
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Devolutions.Utils.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Devolutions.Windows.Utils.dll
1> Compiling assembly C:\Program Files (x86)\Devolutions\Remote Desktop Manager\Devolutions.Windows.Utils.dll (CLR v4.0.30319) ...
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Devolutions.Windows.Utils.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Newtonsoft.Json.dll
Compiling assembly C:\Program Files (x86)\Devolutions\Remote Desktop Manager\Newtonsoft.Json.dll (CLR v2.0.50727) ...
Newtonsoft.Json, Version=4.5.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Newtonsoft.Json.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Devolutions.Server.ApiWrapper.dll
2> Compiling assembly RemoteDesktopManager.Business, Version=11.0.6.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
1> Compiling assembly C:\Program Files (x86)\Devolutions\Remote Desktop Manager\Devolutions.Server.ApiWrapper.dll (CLR v4.0.30319) ...
4> Compiling assembly Devolutions, Version=11.0.6.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
3> Compiling assembly RemoteDesktopManager.AddOn, Version=11.0.6.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Devolutions.Server.ApiWrapper.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install RemoteDesktopManager.AddOn.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install RemoteDesktopManager.AddOn.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Devolutions.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Devolutions.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install Devolutions.VMwareManagement.dll /nodependencies
Failed to load dependency VMware.Vim of assembly Devolutions.VMwareManagement, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
1> Compiling assembly C:\Program Files (x86)\Devolutions\Remote Desktop Manager\Devolutions.VMwareManagement.dll (CLR v4.0.30319) ...
1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'VMware.Vim, Version=5.5.0.0, Culture=neutral, PublicKeyToken=10980b081e887e9f' or one of its dependencies. The system cannot find the file specified.. If this assembly is found during runtime of an application, then the native image currently being generated will not be used.
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install Devolutions.VMwareManagement.dll /nodependencies
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install RemoteDesktopManager.Business.dll /nodependencies
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install RemoteDesktopManager.Business.dll /nodependencies
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install RemoteDesktopManager.Business.XmlSerializers.dll /nodependencies
1> Compiling assembly C:\Program Files (x86)\Devolutions\Remote Desktop Manager\RemoteDesktopManager.Business.XmlSerializers.dll (CLR v4.0.30319) ...
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install RemoteDesktopManager.Business.XmlSerializers.dll /nodependencies
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install RemoteDesktopManager.Core.dll /nodependencies
Failed to load dependency Microsoft.Web.Administration of assembly RemoteDesktopManager.Core, Version=11.0.6.0, Culture=neutral, PublicKeyToken=null because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
1> Compiling assembly C:\Program Files (x86)\Devolutions\Remote Desktop Manager\RemoteDesktopManager.Core.dll (CLR v4.0.30319) ...
1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.Web.Administration, Version=7.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.. If this assembly is found during runtime of an application, then the native image currently being generated will not be used.
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install RemoteDesktopManager.Core.dll /nodependencies
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install RemoteDesktopManager.Core.XmlSerializers.dll /nodependencies
1> Compiling assembly C:\Program Files (x86)\Devolutions\Remote Desktop Manager\RemoteDesktopManager.Core.XmlSerializers.dll (CLR v4.0.30319) ...
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install RemoteDesktopManager.Core.XmlSerializers.dll /nodependencies
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install RemoteDesktopManager.Proxies.dll
1> Compiling assembly C:\Program Files (x86)\Devolutions\Remote Desktop Manager\RemoteDesktopManager.Proxies.dll (CLR v4.0.30319) ...
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install RemoteDesktopManager.Proxies.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install RemoteDesktopManager.Proxies.XmlSerializers.dll
1> Compiling assembly C:\Program Files (x86)\Devolutions\Remote Desktop Manager\RemoteDesktopManager.Proxies.XmlSerializers.dll (CLR v4.0.30319) ...
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install RemoteDesktopManager.Proxies.XmlSerializers.dll
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install RemoteDesktopManager.exe /nodependencies
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\ngen.exe install RemoteDesktopManager64.exe /nodependencies
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>REM -------------- Others --------------
C:\Program Files (x86)\Devolutions\Remote Desktop Manager>REM C:\Windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe install RemoteDesktopManager.PowerShell.dll /nodependencies
Those errors are normal. We will see if this help when you will execute the next installer.
I tried installing the 11.0.7 update and it worked - thanks for your help!
