PowerTools - RunAs
The optional Power Tools are great to fastly restart or shutdown one or more devices. Unfortunately it is not possible to use different credentials to start those Tools.
Problem:
I am starting the RDM with a normal Windows user for my daily work as I do not use an administrative account. If I like to use the power Tools I do not have the proper rights to pursue those Tasks as the user I started the RDM with.
Work around so far:
Start RDM with an administrative user.
Wish:
Implement a right click Option or Setting within the program that it is at least possible to use my Standard credentials within my private vault similar to i.e. connecting to a RDP session.
All Comments (18)
Hi Stefan.
I will verify if it's technically possible to do the impersonate.
Stefan - Could you post a print screen of where/what/how you see this working?
Do you want to "Run As Admin" of the current user or "Run As Admin" using a different user? Both?
Stéfane Lavergne
Hi Stefane,
I would like to see the RunAs different user, ideally as with an RDP session the button "Open session and choose logon data" or just use the personal data within My Account Settings.
Please be anxious about my wording as I am using a german localized RDM and often do not know the exact english button declaration.
If necessary I can send you a screenshot but either way I just would like to see that I can sepcify a different user to run the PowerTools with.
Hi Stefan,
No problem with the German screen shot, please send them anyways, it will help understand where you want this feature.
Run-As has been added a few places on a "on-demand" basis. We don't have time to add it everywhere so if you tell me exactly where you need it I can focus on those first.
Stéfane Lavergne
Hi Stefane,
if possible I would like to choose the credentials similar to an RDP session. So it should be possible to just right click the Shutdown/Restart Computer and choose to use different credentials.
Please find two screenshots. One Shows how right click should behave. Apparently it Shows the correct menu but it is not for the Shutdown tool but the RDP session itself.
The other screenshot shows the expected credential picker as known from i.e. an RDP session.
Where am I able to upload an image? I am sure that it is possible to upload images while creating a new topic but it seems not with Quick Reply :-(
To upload a file you must use the "Add reply" or you can Edit an existing message to add a file. Quick Reply if for text only.
Stéfane Lavergne
Hi Stefane
thanks for the info. I did upload the two images within my previous post. I am hoping it was able to clear things up and not make it even more complicated.
Thank you for the info. I will see what we can do with this.
Stéfane Lavergne
