Default (comment) log entry
jan-pieter
Disabled
With sessions you have the option for "Prompt for comment op open/close" and "Open comment is required".
Is it possible to add a default prompt? So if the prompt comes up it is filled with the default prompt for this specific session.
Jan-Pieter
All Comments (4)
I will add a feature request for that.
KajLehtinen
Disabled
Has this made its way into RDM? Would like to insert a text to explain that the user needs to enter ticket number for why they need to connect
It's not available yet.
The ticket number will be available in RDM 14.
