Execute Powershell Script on Teamviewer connection
hiho,
ich have many TV connection with a IP as ID, bt i cant execute a ps script on this connection.
Why?
All Comments (10)
We havent implemented this to run against the ID of a teamviewer session.
In fact I'm surprised the tool are even showing when a teamviewer session is selected. We will discuss this internally.
Maurice
are there any updates on this Topic? We would like to use ps scripts on teamviewer connections.
There is no way for us to send the PowerShell to the Team Viewer connection. What do you have in mind exactly perhaps I've just misunderstood the request.
we want just a simple ping
warminhg up this Topic:
What is want is very simple ... i have a teamviwer connection with an IP Adress, not with an TVID.
What can i do to execute a ping con this connection to check the reachability of the host.
i know that i cant ping a TVID and dont want to send something into the teamviewer connection. Just a simple ping.
Hello Sid,
So if I understand correctly we could use the TVID as a host and enable the TV connection type to support ping?
jep , right
Perfect. This is now on my todo list.
This will be in the next beta release.
fine, thxs
