Cannot connect to SQL Server in Android using SSL connection
I'm trying to setup my SQL database connection in Android app. My SQL Server uses SSL for encrypting traffic (forced). I get the error message "server closed the connection". When I check the SQL log, it says that the client doesn't support encryption.
Is this feature going to be supported?
Thank you
Sorry but for now there is no available component to implement SSL encryption with a SQL server connection.
André Sanscartier
The only solution is to use DVLS (Devolutions Server) if you need an encrypted SQL Server connection.
Sorry about that.
