RD Gateway Connections not always logging on
When I connect using MSRDP to a server with a Remote Desktop Gateway defined, it doesn't always connect. Sometimes it takes 3-4 tries before it finally opens up the session.
Most times, it just sits there with "Connecting to host...", doing nothing. What's also odd is that it never times out.
Thoughts? Need log file or anything?
All Comments (7)
Hello Jesper,
We have made few fixes last week related to the initial connection. What version do you currently use?
v2.5.5.0
Hi Jesper,
When you say that it takes 3-4 tries do you mean that you need to open and close the session 3-4 times?
Could you send me a log file from this session? You can configure the log in the advanced tab of the session with the log filter set to com.freerdp.*:debug
You can then send it directly to me at bsansregret@devolutions.net
Benoît Sansregret
Sending the email to you now...
Thank you Jesper We will check that as soon as possible
Benoît Sansregret
This is still an issue in v3.0.3.0 when Sandboxing is turned on. I have had RDM crash too many times with Sandboxing Off taking down the entire set of sessions (4-5 typically) that it's becoming problematic.
Are you closer to a solution?
Next release will contain some fixes that might be related to your issue.
Since we are not able to reproduce your issue consistently it's not a promise it will fix your issue but it's a start.
It should be available in the next few days
Best Regards,
Benoît Sansregret
