how many connections are possible?
If i try to connect more then 16 i get a message : "Die Sitzung wurde aufgrund eines Protokollfehlers getrennt"
what can i do ?
best regards
Egbert
There's no fixed limit, it depends on the "experience" tab of the sessions that you are using. You could support more by disabling a lot of the visual quality settings, as well as lowering the cache.
Another alternative would be to use the 64 bit edition, but it doesn't support 100% of the features.
http://blog.devolutions.net/2014/07/memory-consumption-tuning-for-rdp-sessions.html
Maurice
