Subject: Taskbar menu - right click - wrong side
Howdy,
When you have a dual monitor setup and you remote (RDP) into the main screen the right click shows on the NON-active screen.
I have the taskbar on the left side of the right monitor.
The program should have the right click menu show on the monitor that has the taskbar.
See attached graphic file for a better explanation.
Bottom line it is not a major bug but an annoyance.
Other than that....love the product.
So much that we are buying a site license for our 30+ IT staff to use as needed...just waiting on our purchasing dept!
Let me know if you have any questions on my bug.
Stefane is currently looking at this problem but we don't really have control on it. It's controlled by Windows.
This is now in the beta version 8.0.10
I installed the latest version and this fix works great!
Thanks for fixing this!!:)
