The Data Entry button greys out if I select more than 1 credential entry. Is there anyway to do more than one at a time?
Which data entry button? Could you post a print screen?
See attached screenshot. If I only have 1 credential entry selected the fields for Data Entry and Web are clickable. If I select more than one they grey out. I'm just trying to see if there is a way to do a batch conversion instead of doing each one individually.
Hi Chris,
I will ask LP to verify what is missing. I agree with you that this should work in batch. Perhaps there is a technical issue that I'm missing.
He will be back to you with the answer.
Hello Chris,
Up until now we weren't allowing batch refactoring of credentials to Data/Web entries since we allowed users to rename the entry. I made changes allowing batch refactoring, however the renaming option won't be available when refactoring multiple entries at once.
is this ok with you?
regards,
Works for me. Thanks.
Hello Chris,
regards,
Is this going to be in a new release or is there something I can do on my end?
Just installed the beta and confirmed it worked. Is it possible to change other features when doing the converting? An example would be changing the icon?
