Installation problem on XP
I'm trying to install the free version of RDM on an old XP system to see how I like it, but it tells me that .NET 4.5 is required for the install. Unfortunately, Microsoft won't let me install .NET 4.5 on XP - the best I can do is .NET 4.0.
How do I get around this difficulty?
All Comments (2)
Could you try to install the zip file instead? It supposed to work only with .Net 4.0
That worked. The MSI file, though, says that .NET 4.5 is required and refuses to install.
