Embeded vs External Using RDM IE Ext
The Devolutions forum site works externally with the auto fill but will not work in embedded mode and I ran into a few sites that work same way externally but not embedded. Am I missing something?
All Comments (4)
What do you use for embedded mode: Firefox or IE?
I use IE 9
I've just tried and it works fine for me with this config:
David, thanks for the screenshot as I was able to click discover again and the fields populated with data in the auto fill section as they were blank. It works now. Thanks again.
