Mac 2.5.0.0 "peer connection lost" on all connections using LastPass to retrieve password
I am so weary of the way the Mac client just breaks things that sorta, kinda worked.
Here's how I run:
I specify an RDG entry with a password stored in the local database for each connection. The server connection itself uses a LastPass lookup to retrieve the destination server login password from a stored note of type "server" in LastPass
This barely worked for the longest time -- and 2.5.0.0 breaks it completely with a "peer connection lost" message.
You guys have a a great product and are very responsive.
But the Mac client isn't very good. It's been nearly useless to me for a long time. Now, you've achieved perfection: I can't use it at all.
All Comments (2)
Do you know if it's the LastPass connection or the RDP connection that is the issue? Does it work with the version 2.0?
The major problem that we have with the Mac version is always the same. RDP is a complex protocol and it's not supported by Microsoft on Mac.
Does you LastPass connection still work in the Windows version?
