When I go to import -> sessions from rdg file I select my file and nothing happens. This is the latest version of RDCMAN and the latest version of Devolutions Enterprise. Any ideas? I have everything broken into groups in RDCMAN.
Hi jknash,
I have tested the import from RDCMan 2.7 to RDM 10.9.0.0 and it works for me.
What version of RDCMan are you using?
edited by jfdagenais on 5/29/2015
2.7 and 2.0.4.0. I see a lot of these entries in the log:
at Devolutions.RemoteDesktopManager.Managers.SessionMenuManager+<mnuImportFromRDCM_Click>c__AnonStorey3.<>m__0 (System.String[] fileNames) [0x00000] in <filename unknown>:0
I will assign this to the Mac team. Perhaps they don't have the latest update like the Windows has.
Thanks!
Your issue is now fixed internally. It will be fix in 2.5.1.0.
Benoît Sansregret
