Using Variables with Macros doesn't work
we are trying to create macros for our connections to enter credentials.
Example:
Cisco ASDM doesn't accept parameters as it is startet as an .jnlp-File
we call Url: https://firewallip/admin/public/asdm.jnlp
Credentials are from repository
in events: after connection execute typing macro:
{WINDOW:ASDM-IDM} ... to get sure the login-window is focused
{DELAY} ... java is slow
{BS} ... to clean saved username
$USERNAME$
{TAB}
$PASSWORD$
{ENTER}
Problem: when using Username&Password-Variables it enters nothing - blank.
when replacing Variables with static credentials it works.
i think it should work with inherited and credentials from store ...
& as my colleague tested -> if we create a connection-entry for cli Variables will work...
We use Server 1.1.3 with RDM 8.0.6.0
EDIT:
Using Variable $MACRO_PASSWORD$ works
edited by SMG on 12/5/2012
Kind Regards
Markus
All Comments (8)
Is it only the password which is empty?
lol, you are funny :)
no, it's from repostitory - and i'm shure repo-entry is not empty, because we are using it
for rdp-sessions & ssh .....
Kind Regards
Markus
Sorry I mean, is it only the password which blank when it's executed?Does the username contains the right value in the script. I'm asking that because in the advanced tab found in session, you have a checkbox to allow Password in variable
i understand,
yes option in advanced is checked to allow PW-Var
Kind Regards
Markus
Would you mind to send me an export of the session (without the credentials, I will simulate the connection)?
need a contact-address ...
if you want receive that session -> it's absolut confidential (also without pw)
Kind Regards
Markus
No problem and you can change the host name and the username too. Send it to dhervieux at devolutions.net
sent you a mail ;)
Kind Regards
Markus
