Office 365 power shell.
Not sure if anybody can help here but.
to add full mailbox and send as permissions for Exchange in O365 you need to use PowerShell.
the commands are.
This logs you on to the O365 server
$LiveCred = Get-Credential $Session = New-PSSession -ConfigurationName Microsoft.Exchange -ConnectionUri https://ps.outlook.com/powershell/ -Credential $LiveCred -Authentication Basic –AllowRedirection
Import-PSSession $Session
Then these commands ad the permissions.
Add-MailboxPermission sam@vaughandata.co.uk -User joe@vaughandata.co.uk -AccessRights FullAccess
Add-MailboxPermission sam@vaughandata.co.uk -User joe@vaughandata.co.uk -AccessRights sendas
can I make a set of commands available in rdm???
Thanks James.
All Comments (6)
I'm not sure I understand. What do you want from RDM?
I need to be able to run the commands from RDM. I cannot link to a ps1 as most pc block running scripts.
im sure its simple but not sure how to do it.
Have you tried to create a Macro/Script/Tool and select PowerShell?
yes I have played about but I need to run the lines separate. eg.
then asked for credentials
then I need to type the commands I want.
but I want the two above commands to run as the user clicks the connector in RDM :)
I think that you can write one power shell and maybe prompt for parameters:
http://stackoverflow.com/questions/8184167/how-to-prompt-for-input-in-powershell
