CTRL-F seem to not work within embedded window
CTRL-F always brings up the filter dialogue when I try to use it inside the RDP window :(
All Comments (1)
Quick workaround is to enable "Grab the keyboard input" icon in the bottom right of the RDM application. If you enable that before your session of just keep it enabled you will be able to do the CTRL+F and not have your search query go to the bottom right filter session section.
