After fresh installation - It's not possible to open Options Tab
I have installed 4 Computers with no problems.
The 5th installation is fresh.
I can open every tab, but not the > File > Options.
Dekstop Manager Free was installed before.
I have deinstalled it an installed the full version normally.
After that, i deinstalled Dekstop Manager Enterprise and clean the programm directories.
After that a new installation of Desktop Manager Enterprise.
But the problem still appears.
Any solutions?
edited by thomas.wehner@baumann-automation.com on 4/14/2015
Hi Thomas,
Do you use the application policy?
I think not.
Fresh install.
I have connected to the db in the network. (Even so as on the 4 other Admin PC's)
That's all.
The user account in which is Desktop Manager Enterprise installed is an admin account.
Start as administrator... didn't help too
This is really strange, could you post a print screen of the backview File?
How can i get this "backview file"?
Program protocol?
Protocol of changes?
Diagnose?
Profiler?
edited by thomas.wehner@baumann-automation.com on 4/15/2015
Sorry for the confusion. the backview is the blue section when you click the menu File.
I have verified the code directly and I don't see anything special. Just to confirm do you get a message when you click Options?
Do you know if this computer has a dual screen?
No. If i click options. Nothing happens.
Every other menue point ist available and works normal.
It's a laptop. At this moment there is no second screen active.
What data source type do you use?
We use 2 SQLite databases.
Workstations
Server (with data source password)
SQL Lite or SQL Server? It's really not recommended to share a SQL Lite database. Could you go in the ribbon Help and execute a Diagnostic?
I have send a diagnostic report.
At this moment i install on a server an MS SQL Express 2014.
Tooks some time.
After that i hope i can export/import SQLite <> MSSQL Server.
I'm really puzzled. I don't see anything special in the diagnostic. Could you try to unzip it in another folder not located in program files. For example in C:\RDM
You don't have to remove the installation and it's just for a test.
