Navigation Focusing Wrong Session
My issue is the same as the one listed here. I have the navigation sidebar unpinned so it is minimized and I have my search bar on the bottom of the application. When I do a search that lists more than one entry I can select any of them and the dashboard will display the correct name, but when I run any tool or macro it runs on a different session. I tested and if I expand the navigation sidebar it works. For example, if I pin the navigation bar after searching for rmw202 and select rmw202-18475, then unpin the navigation bar and do the same query - rmw202 - then select a different session like rmw202-18474 from the search popup the dashboard will say the session is rmw202-18474. But when I run any tool or macro it will run as rmw202-18475. If I change my query after unpinning the nav bar any macro I run will run as the first session listed in the popup filter box regardless of which I pick, I have to unpin the nav bar and select the different session, or do a query that returns a single session to run on the session I want. I've attached 2 screenshots, one shows the dashboard displaying a session and a tab that I ran from that session which ran as the wrong session. The second shows the unpinned nav bar and how it doesn't update when the popup filter box does.
RDM 10.5.1.0 Enterprise
Windows 7 Enterprise x64
.NET Runtime v4.0.30319
Hi burgler00,
In the Navigation Pane, which session is selected? Is it RMW202-16149 or another one?
edited by jfdagenais on 4/8/2015
The navigation pane selects either the first entry, if the query is a new one. Or, if the query was the same and the previous selection was made via the navigation pane the session selected is the previous one, not the one selected in the popup search. The "rdm.png" attachment illustrates this, I opened the navigation pane and manually selected RMW202-16135, then re-searched for RMW202 in the search box and highlighted RMW202-16149. The dashboard name changed, but any macros or connections I made were to RMW202-16135 -and that was the entry highlighted in the navigation pane.
Hi burgler00,
Could you send us a small video of the issue at support@devolutions.net please.
