Best practice config for max performance (minimal session types)
Hello all - we are having some pretty significant slowness in our Citrix environment running RDM. Is there a best practice guide or list of items we could look at / implement to ensure that the following are tuned well for max performance?
  • database sizing and tuning / maintenance and table cleanups that can be done
  • CPU / ram sizing for a citrix / terminal server running RDM (in a multi-user scenario)
  • Tuning guide for RDM if we only use (RDP, telnet, putty, and web connections)
  • Disk IO requirements on the database side and the server side running RDM for reasonable performance
Our environment specs :
  • Windows server 2012r2 - on generation 1 VM on HyperV > on Cisco UCS / 4vcpu / 32Gig ram
  • Citrix XenApp 7.6 running on this VM (I have 2 servers)
  • RDM version 10.1.9.0 / .NET runtime: v4.0.30319 / Remote Desktop: 6.3.9600.16384
  • Database environment (2012R2 VM - gen1 on huperV on UCS / 2 node alwaysOn via SQL 2012)
  • RDM is connected to common SQL database / we use the config file in program files on each citrix server to ensure license / datasource is common
thanks for any guidance,
-jason
All Comments (1)
I will put the short versions of the answers here and then we will add them to our online help.
  • database sizing and tuning, cannot generalize this, we create indexes when we identify issues. When a customer has an issue we ask for logs and analyze their content. Using Custom images and significant free text entries in the Notes and Description fields increase the size of the DB, but also the data that travels on the wire.
  • database maintenance: the following tables increase in size and must be pruned either using RDM's interface or even sometimes by manipulating the database directly.
    • Usage Log : Directly in the DB - pruning the ConnectionLog table
    • Deleted entries : Administration - View Deleted, then Delete selectively or Delete All
    • Entry History : Directly in the DB - pruning the ConnectionHistory table, the Field HistoryType contains I for inserts, U for updates, and D for deletions. The implementation of a cleanup feature that we are looking at right now would preserve the last X revisions, but ensuring we also kept the last X days of history. Thats a strategy that I would recommend you follow as well.
  • CPU/RAM Sizing: we cannot know what other tools will be running in your environment. Do you see an issue with cpu/memory usage of RDM in your various sessions?
  • Tuning: each technology is widely different. For RDP I would reduce the cache and choose a lower "Experience" setting for sure, for other technologies I can't see a general suggestion to make.
  • Disk IO: again this depends on your environment. Are users launching sessions every minute, or once in a while? For the DB there are general recommendations like having the log device on a different volume and so on, but we have no requirements that dictate a specific target for any of the settings.
If you feel that the system is sluggish, you could start by following the steps in Diagnostic and send us the results.
Maurice
