right click on the tabbed icon for logoff
What about adding right click on the tabbed icon for logoff ?
All Comments (12)
Added to my todo list. It's already there when you do it on the tree view.
One of the best way to log off as most software these days have such function.
I know it's there but when you opened several connections and you made a search on the tree you cannot logoff the opened servers. You need to find them again in the tree...
It's done and this will be in the next beta release.
I would suggest to make an automatic logoff when closing the tab. This would be great as an optional connection feature.
This is a good idea but more tricky. RDP does not support logoff directly. We need a Terminal Services API to do it and it requires specific rights.
Do you think you can realize this?
I'm not sure. I'm afraid that this will create more confusion since most people don't have the right to execute the logoff and they won't understand why RDM does not work.
Logging off from a server to which I am connected by custom credentials (not by the same credentials I'm currently logged on with to my local machine) results in "Unable to enumerate remote sessions".
I think you should enumerate the remote sessions with the same user whom session I want to log off from.
Could you try to set the credential to "Use session credentials" in the Tool tab page of your session. I think that could be a workaround.
I still get the same error.
Could you take a look at this topic?
http://help.remotedesktopmanager.com/troubleshooting_logoffaccessdeniederror.htm
