Clear filter on open connection
With "Clear filter on open connection" is it possible to set the focus on this connection in tree view after connection?
Thanks for any help.
Best regards
Michael
All Comments (5)
Where your focus goes exactly now?
Hi David,
As far as we can see it only happens with connections, where display is not embedded (like Teamviewer connections). The focus stays on the entry, which was highlighted before.
Michael
Thank you for the details
This issue will be fixed in the next RDM version. The focus will be put on the selected connection as it should have.
Perfect. Thanks for your support
Michael
