Freez issue when connection is lost
Hi all,
I have an issue for some time.If I got more than 2 connections open (mostly native ssh) if one of my servers reboots or for some reason the connection is lost the RDM got freez state (white screen) and i just need to kill it and restart it.It never reconnects or just close that particulat connection tab.
Can this be somehow fixed?
Windows 7 x64
RDM ent : 10.1.9.0
thank you.
edited by nikkon on 3/8/2015
All Comments (6)
Could you try the latest RDM beta version? We've made fix for something similar to your issue.
http://remotedesktopmanager.com/Home/Download#beta
thank you.I'll update on this asap.
it seems to work.it just disconnects fast and keep the up running.
Thanks.
After several test i got the same issue...once the connection dies (VPN for example - vpn timeout) even if i use only one instance connceted via that route...the entire soft freez and dies.
What RDM version?
Herehere, same issue with SSH session and RDP session are active.
After that, restarting the Windows machine on which we have an RDP open, the whole RDM goes white.
Must be something together with SSH?
RDM version 11.1.0.0
