I have an entry to logon to an internal URL and I need it to pass my ID/PW from the credential repository and use either DOMAIN\username or username@domain.com. Nothing I try seems to work.
I have tried going to the LOGIN tab and tried changing the "username ID" field to use one of the variables (like $USERNAME$) and the username field on the webpage is just blank.
Any recommendations how I can get this to work?
Thanks,
edited by ben732 on 2/19/2015
Ben Liebowitz, VCP, vExpert
Hi Ben
I think you are doing it wrong(or I'm just tired and misreading :) ).
1. [General tab] Input Web browser URL
2. [Login tab] Clear all fields below "Form login"(the lower part)
3. Press the button "Discover"
Does that return/input anything into the "ID" fields?
//Brandur
//Brandur
Hi Brandur,
I orignally set it up with the DISCOVER button, and it fills in "username" in that field, however, when it fills in the field, it only puts my username and the domain is not listed anywhere...
There is not a separate field for domain, so the username field needs to be filled in with username@domain.com OR domain\username.
Thanks,
Hi Ben Liebowitz,
In the login tab, you have a username, domain and password fields. Have you entered the proper information in those fields?
Hi Ben
I think you might be misunderstanding this.
I attached an example, but I would recommend that you start using the credential repository, instead of hard-coding sessions with specific domain/usernames.
//Brandur
//Brandur
Hi Jean-Francois,
I am using the Credential Repository which has my domain user account. I use this Credential Repository entry to login to all my windows servers with no issue. As I need to pass the same information to login to this URL, I am trying to use the same Credential entry.
