Problem with personal credentials in 10.1.10.0 BETA
I just upgraded to the latest BETA (10.1.10.0) and My Personal Credentials are gone. When I try to set them again in RDM, it takes me to the default "Add a New Credential" entry screen. My day is over and I'm heading home, but please check this issue (sounds generic so I'm guessing you can probably duplicate?). I'm using a SQL DB data source.
Thanks
I've just checked and seem to work for me. I know that Maurice has fixed an issue where the personal credentials was saved at the wrong location. Could you verify if you can re-save them again?
I checked as well and they saved and persisted properly across application restarts.
Maurice
Thank you both for the info. I didn't want to make any changes before I got feedback from you all. So I went ahead and re-entered my personal credentials again (selecting the username/password option from the choice of credential possibilities) and then I tested RDM (restarting RDM, rebooting my PC, etc.), and following the various tests, my personal credentials seem to work properly like they did before. So I'm going to guess that everything is OK and they just had to be re-entered after installing the most recent update for some reason.
Thanks again
edited by STGdb on 2/14/2015
