Multiple SSH sessions for same device
Recent convert from MobaXterm Pro to RDM user, however after searching help and forums I
can't find an answer as to how to allow multiple SSH sessions to the same host. When I right-click
on the SSH session I'm trying to have an additional session open up to it focuses me on my existing connection.
How is this accomplished?
TIA...
All Comments (5)
First of all, Welcome to our community!!!!
The setting to allow that is in the advanced tab of the session, its called "allow open multiple connections"
Maurice
Thank you - worked like a charm.
So I don't have to go back and change each entry, can I change the "default" setting to "True" in just one place?
Sure, sorry about not mentioning it
File - Options - General - the Connection section, Allow multiple connections (Default).
Maurice
Thanks again - Worked fine. I was trying to accomplish it by right-clicking on the parent group folder and changing it there.
Thanks!
David
lucvdv
Disabled
And thanks from me too. I was having the same problem.
