Question: Is it possible to mandate a dialog box to populate Custom variables?
When I deploy a template, the custom variables are not populated by default.
Is there a way to add a prompt box to populate the Custom variables?
It was recently added to the newer versions of RDM, asking to rename the group/folder. Was wondering if this could be extended to other fields?
Thanks.
You would like to use the custom variable as a placeholder populated at the template creation?
Yes.
Good,
I will enter a feature request for that.
