Filter Box Loses Focus
I used to be able to click in the filter box and type the name of a server and then hit "enter" to connect, now I click in the box and it immediately loses focus, does anyone else experience this? I am running Remote Desktop Manager 10.1.8.0.
Thanks
Anthony
All Comments (20)
I can't reproduce it. Could you post a print screen? Perhaps you have a different UI than mine?
Hi David,
I am unsure what you mean, please help me understand what it is that you need that may help you understand this issue. I fear a screenshot would only show you a point in time picture of my screen whereas the problem is when I click in the bottom left filter box the focus is there for maybe a second then moves to the RDP session I currently have active.
Anthony
Here is a video of the issue, I only click once in this video and that is on the filter box.
Anthony
did you try to reset layout? it sometimes solves a lot of problems.
you will find it in Window -> Reset Layout
after this close an open RDM again and try again
regards
Markus
Kind Regards
Markus
Hi Markus,
Thank you for the suggestion, I hadn't tried that. I just reset my layout and unfortunately it didn't fix the issue.
Anthony
hm, thats bad,
i too cant reproduce in rdm 10.1.8, it is working.
maybe try to uninstall rdm, manually delete %USERPROFILE%\AppData\Local\Devolutions and reinstall
(dont know which db-type you use, but if local-db do an export before uninstall)
if it occours after fresh install it's maybe not rdm-related.
regards
markus
Kind Regards
Markus
I just retried the reset layout with all options selected and it fixed the problem!
Thank you again.
Anthony
great,
thx for your response
regards
markus
Kind Regards
Markus
Ouch! It's back . . .
does it occour only on your machine? can you test within a vm or another pc?
Kind Regards
Markus
A colleague in my office has the same issue.
strange, i cant figure out the cause ... cant even reproduce... sorry
Kind Regards
Markus
