Strange random credential issue.
After creating a new credential entry with an user account, domain, and password and assigning it to a new RDP session for a windows 2003 server I find that the auto login fails due to an invalid password. The password is correct, but if I re-enter the password and press the enter key instead of the tab key or clicking the OK button the issue is resolved. This seems to only affect a few Windows 2003 server, but has happened enough so I know it’s not a fluke.
edited by Kattywumpus on 8/9/2012
All Comments (5)
Have you tried to open it embedded or in external mode? What do you mean by pressing enter could you post a print screen?
Yes, same result embedded or in external mode once the issue occurs.
edited by Kattywumpus on 8/15/2012
Weird! What happen is you just reveal the password with the button?
The password look correct, no strange characters.
In a few days I will have more users using RDM which may cause the issue to occur again. If it does I will try to get more information.
Let me know and I could create a special build with debug info
