I have saved my Tightvnc connections to a .vnc file. I then import them into RDM as a session. When I used UltraVNC this worked fine. Now using TightVNC I get an invalid command line error.
If I create a session from scratch VNC works fine but I cannot save the password
Any ideas?
Thanks
edited by Raydiognome on 7/21/2012
What version of tightvnc do you use? I know that they update it recently, maybe thay have changed the command line?
I'm using the latest version 2.52 June 26 2012. I'm trying it out compared to my old standby UNVC.
Tight was recommended for better "behavior" on Win 7.
I've just verified and it does not seems to support a vnc config file:
http://tightvnc.com/vncviewer.1.html
Tight VNC works fine if I double-click the VNC config file. It just doesn't work when I use this file within RDM. It's as if something is being translated or implemeted wrong.
Could you try to open the vnc file in command line with Tight vnc?
