Move sessions between data sources
Hello!
I know in 7.1 there was a new version about moving sessions between data sources. We use SQL for our main database, but when techs are off site, they go into offline mode. If they need to create new entries, they add them to their local .XML or Access DB, and then when they have the ability to go online, they'll export the sessions and import them. I just updated my client to 7.5, and I didn't seem to be able to have an option for this when moving sessions. Is this limited to only certain data sources? Note - I have "allow drag and drop" disabled on all the users for the SQL data sources - too many were accidentally moved, so I'm not sure if that has to be allowed to use the feature.
Thank you!
Tom Mucha
All Comments (2)
What do you mean by you don't have this option anymore? The steps were:
1. use the menu Copy from Edit->Clipboard ->Copy
2. select the destination data source
3. paste the content with Edit->Clipboard ->Paste
Ok - thanks! I thought it was a r-click option in the "Move to another group/folder". Thank you!!
