Command window target monitor problem
Hi all!
I have the following problem on a workstation with two monitors attached, the desktop is extended over the two monitors:
I created 3 sessions, run cmd.exe, one with display External, Current Monitor, one with External, Primary Monitor and one with External, Secondary Monitor.
RDM is running in the primary window. The following happens when I start the sessions:
External, Current Monitor => Session starts in primary monitor and moves to the secondary monitor.
External, Primary Monitor => Session starts in primary monitor and moves to the left, outside of the primary monitor.
External, Secondary Monitor => Session starts in primary monitor and moves to the secondary monitor.
How can I configure RDM so the sessions are started in the correct monitor?
Thank you very much for your help in advance!
Kind regards,
Eric van Loon
All Comments (2)
What version are you running?
If you are not on the beta, could you please give it a try.
http://remotedesktopmanager.com/remotedesktopmanager/Home/Download
We've done some major changes with the monitor code.
Thanks
Stéfane Lavergne
Hi Stephane!
Thank you very much for your reply! I just downloaded the binary files version of the beta and tried it, the problem seems to be fixed here. The only problem is that our license recently expired and it doesn't allow us to install any higher version than 7.0.0.0...
Kind regards,
Eric van Loon
KLM Royal Dutch Airlines
Ends in 4 days
