Two RDS entries for same remote server
When I configure two RDS entries for the same server but with different user/login combinations, the sessions interfere with each other. One or the other session will show an invalid login/password. I can add one, it tests successfully, but when I add the second it breaks the first one.
--Guru Amrit
All Comments (7)
which version do you use?
This is a limitation in the Windows Credential Vault. It used the host name for the key. If you save your password in the session directly (Enterprise edition only) you won't have this problem.
I am using Standard version. David, thanks for the explanation. I will purchase Enterprise.
Try this with a trial before.
I just tried this with the Enterprise Trial and it did not work. I created two RDS entries for the same server, both using session specific credentials and the second one still breaks the first.
Have you saved your password in RDM and used the embedded mode?
I tried "Embedded Credential Entry" and it worked. Thanks.
Ends in 6 days
