I don't know if it is a my ignorance, or if it is possible to let to autoadjust window if a remote session (I normally use rdp) start small and then I would to expand to maximum window size
Actually I close connection, expand DesktopManager and then reconnect session
Attached there's an example...
Thanks
Does it help if you use "Smart sizing"?
edited by UggaBugga on 6/29/2012
//Brandur
Hello Uggabubba,
this seems to be the settings that I'm lookin for, but doesn't work in my case. This works only if Desktop manager start already maximized and the windows are resized.
If Client start small, this doesn't work (or I don't know how to do this)
Thankx
Ok.
Unfortunately I'm all out of ideas then.
Maybe David has some suggestions for you! :)
//Brandur
Sorry about the delay. It does not work with the ActiveX. I think that the only solution is to reconnect.
