doubleclick "anywhere" starts selected connection
version: 5.6.0.1 Beta
when a connection is selected and you double click anywhere in the tree view (e.g. expand / collapse a node) the connection is started.
https://www.gpunktschmitz.com
All Comments (5)
It's now fixed in my internal build.
Thank you
Devolutions inc.
confirmed .. fixed in 5.6.0.2 Beta
The bug is still there in a lesser variant…
I’m using version 5.6.3.0, when in Tree view, select to “Collapse All”.
Then only “-> Sessions” is displayed.
My instant reaction is to double-click “Sessions” to expand the tree again. When doing this, all my sessions are opened… all 690 of them…. :)
The Doc
I missed one case when you double click on the root, but it's already fixed in my internal build, this is not an official build but it works fine:
http://remotedesktopmanager.com/download/Devolutions.RemoteDesktopManager.Bin.5.6.3.3.zip
Sorry about that, Ï know it's really painful.
Devolutions inc.
Thanks alot!
I'm so impressed by your level of support, that I'm gonna recomend my company buying an Site License. Thus implemnting this to all of our tech-staff.
The Doc.
