I thought I saw there was a way that one connection could be dependent on another. Is there a way to have an SSH connection setup and an RDP connection setup and have the RDP be dependent on the SSH so that I can just launch the RDP connection and it would then see the SSH connection wasn't live and launch that automatically before trying to connect?
Thanks.
In the VPN tab of the RDP session, first select an active value like "always connect" or "connect if unable to ping"
Then below select "session" in the drop down.
Switch to the settings tab, select your SSH session. You may have to fiddle with the delays depending on the time it takes for the SSH session to be established.
edited by mcote on 1/21/2015
Maurice
