offline mode.... requires connection to DB
This anomaly occurs a few days ... before it worked properly.
in offline mode I try to add any item, but it requires you to connect to the database sql (is my data source).
as you can see the photo the RDM is offline.
I tried to run a Reset and temporary files and updated version but have not solved.
suggestions?
thank you.
Version 11.0.10.0
All Comments (1)
Is it when you try to add any type of connection? We have released RDM 10.1 and it could be a good idea to upgrade to the latest version.
