Is it possible to connect to an AS400 mainframe from Remote Desktop Manager by using Client Access?!
Hello.
I would like to be able to connect to an AS400 mainframe system from Remote Desktop Manager by using Client Access sessions.
Is this possible to implement? How can i do this?
Thank you in advance.
Hugo Rosa
What is this "client access"? A client application, a web access, etc? Will it accept parameters to indicate the host, username, password, etc?
Please send us the link to documentation that you can find.
Maurice
Do you know if we need to call an application?
Hello Maurice and David.
Good news! There is already one add on available that solved my issue!
The Client Access software is a communication package that allows the users to connect, remotely, to the AS400 mainframe systems, from a Windows machine.
But, as i discover, searching for a solution on this website, there is one add on called "IBMPersonnalCommunicationsAddOn.zip" that allows the use of this Client Access software.
So, it's done and solved!
Now, on my case, i have, VPN + Real VNC + RDP + TeamViewer + Citrix + Client Access connections, ALL in one single place, Remote Desktop Manager.
Thank you.
Hugo Rosa
